Other Parts Discussed in Thread: ADS1278
Hello everyone,
I plan to use the ADS1278 on a new project, however I am having some difficulties understanding the Frame-Sync signals described on the datasheet. I would appreciate some help. My questions are:
- What happens if you generate FSYNC signals with lower period than the conversion rate?
- What happens if the FSYNC, running exactly at the conversion rate, if slightly out of of phase (from the initial SYNC signal)
- If you generate the FSYNC signal from a microcontroller that is driven by a different clock source than the ADS1278, even if the timming is very precise and the framing process is synchronized using the SYNC signal, the small crystal drift from both IC will evently result in a alignment drift of FSYNC. It may take some millions/billions conversion cycles or some temperature drift, but it will eventually happens. Is this normal/expected? Is it necessary to issue a new SYNC signal time to time?
Calin
