Part Number: DAC3482
Other Parts Discussed in Thread: DAC38J84
Hi TI Experts,
I have a question about IQ modulator Sideband Correction. QMC gain and phase values are used in my application to correct sideband. A 31.25MHz sine wave at DAC3482 output is used to calibrate QMC gain, phase values, sideband could be corrected to -80dB. Offset values are used to correct LO.
The problem is, when I change DAC output frequency, sideband get worse. I then did QMC calibration at multi-frequencies, it seems different DAC output frequency requires different QMC phase values. The test data are listed below.
IQ Modulator LO = 3.5GHz.
DAC Output Gain I Gain Q Phase
78.13M 1920 1943 156
75.00M 1920 1943 152
68.75M 1920 1943 180
62.50M 1920 1943 180
50.00M 1920 1943 181
40.00M 1920 1943 190
31.25M 1920 1943 193
The real waveform in my application is wideband, thus keep sideband to be low on various frequency is important to ensure good system EVM. So, I like to know, how can I correct sideband for a wide frequency range? Use delay settings?
T.L.
