ADC12DC105: Regarding the handling of AGND and DRGND
Part Number: ADC12DC105
Hi team,
How should AGND and DRGND be handled?
  1. Prepare separate GND planes and connect them at a single point under the ADC. (To prevent the influence of digital noise.)
  2. Connect using a GND plane. (A completely common ground)
Kyohei
  • Hi Kyohei,
    Please use a single ground plane. Good circuit partitioning is key for a proper layout.
    This means, keep clocking circuits in their respective area, keep all digital circuits within their respective area and all analog circuits within their respective area, etc.
    If you need help in reviewing your layout when ready please let us know.
    We are happy to help.
    Rob
  • Hi Rob,
    Thank you for your reply.
    Is it correct to assume that layout (2) is the recommended one?
    Also, in case of layout (1), AGND and DRGND are connected near the exposed pad on the solder side of the ADC. Would this cause any issues?
    Kyohei
  • Hi Kyohei,
    Yes, layout 1 is the recommendation.
    In the case of layout 2, where a and d grounds are separated, there should be a tie point as close to the ADC as possible. Or under the ADC, as you stated above. However, if you tie this point together, then this really puts you back to layout one. You never really needed to separate the ground planes to begin with.
    Rob
