Tool/software:Stm32cube ide & TouchGFX
We are currently using the ADS1293 for 3-lead ECG acquisition in our custom hardware platform. During testing, we’ve observed significant noise artifacts affecting Lead II and Lead III—both mapped to Channel 2 and its differential pair—despite multiple mitigation efforts. Notably, Lead I (Channel 1) consistently provides a clean, stable ECG signal.
To isolate the issue, we replicated the setup using the official ProtoCentral ADS1293 Evaluation Kit. Surprisingly, the same noise behavior persists on Channel 2 (Leads II/III), even under ideal test conditions:
Power Supply: Clean 3.3 V from a low-noise LDO
RLD: Enabled, configured with internal reference and connected to the subject
Electrodes: Medical-grade adhesive ECG pads with verified skin contact
Acquisition Settings: 500 Hz sampling rate with external analog HPF/LPF and a digital 50 Hz notch filter
This consistent behavior across both our hardware and the evaluation kit leads us to believe the issue may be related to:
RLD stability or impedance mismatch
Power supply noise coupling into Channel 2
Internal channel-to-channel crosstalk or routing sensitivity within the ADS1293
We would appreciate your guidance on the following:
Channel 2-specific Recommendations
Are there known best practices or hardware considerations to improve noise rejection on Channel 2?
RLD Optimization
Do you advise any specific RLD configurations (gain, reference source, electrode placement) that could help improve signal quality, particularly for Leads II and III?
Validated Register Settings
Could you share any internally verified ADS1293 register configurations for clean 3-lead ECG acquisition—especially those optimized for Channel 2?
We’re happy to provide raw ECG logs, filtered waveform plots, or board schematics if they would assist your analysis.
Thank you in advance for your support. We look forward to your expert insights.
Warm regards,
Ganesh.
