Hello! I'm prototyping a wearable using AFE4960P dev board, and I need technical information regarding basic configuration schemes:
We are currently evaluating the feasibility of using AFE4960P sensor in our specific system configuration (with scenario similar to wearable devices). While we have reviewed the available datasheets and documentation, and they confirm that our intended use case is feasible in principle, we have found that they do not provide sufficient detail on how to properly implement or optimize the setup for our specific needs. Specifically, how to configure AFE4960PEVM evaluation board (and AFE4960P sensor in our device once we are sure we can acquire desired data) for 1-lead ECG signal acquisition in order to test signal quality using provided Bio-Sensing software.
To proceed with confidence and ensure correct integration, we would greatly appreciate it if you could provide an example (script for Bio-Sensing software) or application note that demonstrates the recommended usage or best practices of the equipment under similar configuration conditions.
If such documentation or guidance is available, even in draft or internal format, it would be extremely helpful for our engineering team. We are particularly interested in:
Typical connection schemes for 1-lead ECG signal acquisition (2 electrodes with and without RLD) and electrode placement
Configuration parameters for Bio-Sensing software for 1-lead ECG signal acquisition (with and without RLD)
Opportunity of fetching register configuration from AFE4960PEVM evaluation board and its usage with AFE4960P in our device
Any considerations or constraints (if applicable)
Any known integration challenges or caveats
