Other Parts Discussed in Thread: BP-DAC11001EVM
Hello team,
Could you tell me output impedance value of SDO of DAC11001B?
The information helps to consider dumping resistor value.
Hello team,
Hello Sanjay-san,
Thank you for your support. I wait for the update.
What we want to define with the information is not pull up resistor but a damping resistor in series.
Hi Taketo-san,
Can you please help with more details on this specific needs? I will check with my design team and get the right answer.
Sanjay
Hello Sanjay-san,
In case device and controller is not located close each other, we have to consider reflection behavior. I believe series resistance help some this situation.
BP-DAC11001EVM also has 33ohm in SDO line. How did you define the resistance value?
Hi Taketo-san,
Thanks for the details, please give me few days to get the details. I hope it should be okay.
Sanjay
Hi Taketo-san,
Our design team did a simulation for SDO output impedance and here is result -
Power supply = 5V.
Pull-down (ohm) : weak - 84.5, nom : 58.22 ad strong : 47.71
Pull-up (ohm) : weak - 54.93, nom : 37.94 ad strong : 29.25
Do let me know for any other details if needed.
Sanjay
