ADS5474-SP: Inquiry about exposed PAD
Guru 12130 points
Part Number: ADS5474-SP
My customer has some questions about the ADS5474-SP exposed PAD.
Q1. Is gold plating a mandatory recommendation when designing a PCB for exposed PAD?
Q2. What is the recommended solder contact ratio between the exposed PAD and the PCB pad?
Thank you.
JH
  • Hi JH,
    Q1. Is gold plating a mandatory recommendation when designing a PCB for exposed PAD? RR: no
    Q2. What is the recommended solder contact ratio between the exposed PAD and the PCB pad? RR: not sure I understand this question? Do you mean how much solder paste should be put down on the pcb for the device's exposed PAD to robustly connect?
    Rob
  • Hi Rob,
    Thank you for your reply.
    The customer asked what the recommended solder contact ratio is between the exposed pad of the ADS5474-SP and the PCB pad after SMT.
    JH
  • Hi JH,
    I don't think we have specific data on the ratio. Its best to have adequate coverage across the entire epad to make sure there is a robust electrical and thermal connection between the pcb and device.
    Sorry, we just don't have a exact number.
    The only reason, I would assume the customer would ask, is if they are planning to change or modify the epad. So please advise against that, if so.
    Rob
