Part Number: TXB0104
Hi
We are using TXB0104RUTR voltage translator in the design to convert 1 wire DQ signal from 3.3V to 1.8V. This design did not work for us we are not getting correct data from this signal. After reading the datasheet came to know that this IC is not recommended for I2C and 1 Wire application. So we are looking for possible replacement. The DQ signal is a open drain signal. As we already designed the PCB so looking the replacement in 12-UQFN package. Do you have any possible replacement?
