TX75E16: Regarding pulser output timing variation between ICs
Part Number: TX75E16
When generating pulser outputs, we observe a timing deviation of approximately ±6 ns between chips in the pulser output timing referenced to the TR_BF_SYNC pin.
Is this level of timing variation considered normal?
Since a 160 MHz clock is used, the timing variation corresponds to one clock cycle.
As shown in the first image, the TR_BF_SYNC pin timing is identical. However, as shown in the second image, there is a timing difference in the outputs from the chips.
We would appreciate your prompt response. Thank you.
