Part Number: ADS131M08
I have been requested to contact through this channel instead of through support channels.
I saw this conversation from a few years ago, but it wasn;t publicly finalised.
Can you confirm or deny if any further investigations into root cause were conducted for the shift this customer saw in their tests? Our applications would be affected if there is a known failure mode that can force the internal reference voltage to shift, assuming that the digital scaling factor of the conversion circuitry in the IC is static (I'm assuming this is set once at factory, I have asked a separate technical question about this).
If there is a known root cause to this symptom, perhaps we can detect it in our application and take actions to reset the AFE if we detect the root cause has occurred in the field.
