Part Number: ADS1120EVM
Hello, I have probably a silly question. I've been getting what seems to be unpredictable data output codes. I wanted to check and make sure that I got the wiring correct. From left to right, EXC- has the black ground/neutral wire, IN- has the white signal wire, IN+ has the green signal wire, and EXC+ has the red live wire.
I just wanted to double check and make sure this is the correct wiring before I plug it in.
Okay, thank you. Here is my wiring.
Okay, thank you. Hopefully, I got it right this time.
