Part Number: AMC0306M05-Q1
Below is our SCH for HV input side current measurement.
Below is power supply when only Auxiliary power is on. 3V3_LV(DVDD) at low voltage side powers on firstly. After 132ms, 5V0_HV(AVDD) at high voltage side powers on later.
We draw the HV input current. We see a maximum negative current(-64A) jump to maximum positive current(64A) within ~5ms. It doesn't make sense. We only power on auxiliary power, no HV input current now. Therefore, the senser output is wrong. Could you pls specify what's happening here?The senser power isn't stablished during this 5ms? Do I need to capture senser power supply and data signal(DOUT) together?
