ADS131A02: External Vref Range
Part Number: ADS131A02
Hi TIer
My customer currently design external reference for ads131A02.
ADS131A02 use ±2.5V for AVDD AVSS power supply.
We know the VREF_external need in  -0.5V to 2V range with GND. So the maximum vref is 4.5V which refer AVSS.
But customer want use external 5V (to AVSS) with refernece but the input range in ±2V.
Can customer use it , if they don't need rail to rail input and output.Can this solution working normally?
Thank you very much.
  • Hi Tony,
    When the reference voltage is 5V, the full-scale range is -Vref/Gain ~ +Vref/Gain, which is theoretically -5V/Gain~ +5V/Gain.  If the input signal is ±2V because of the input/supply limit, the ADC will not output any conversion code for the voltage above +2V and the voltage below -2V, so the customer will not be able to take advance of the full-scale range of the ADC. I did not seen any benefit to use a 5V reference, 2V reference voltage (REFEXT – REFN) is enough or using internal 2.442V reference is a good option.
    BR,
    Dale
  • Thank you got it.
