Other Parts Discussed in Thread: ADS1259EVM-PDK, ADCPRO, PGA280
Hello all,
I just got an ADS1259EVM-PDK, and want to use it for some data measurement purposes. I downloaded all the latest software and drivers from TI website. I applied the necessary power supplies to the EVM, and gave a differential input to INN1 and INP1 on connector J8. I also changed the EVM setting according to my needs in ADCPro after loading the EVM.
After those setups, I loaded MultiScope test and gave a block size of 983340. I selected the sampling rate as 14400SPS. Everything was running okay, and I could get the input differential voltages without any problems. Now, if I changed the sampling rate to 60SPS and remained the block size as 983340, the EVM took about 5 hours to acquire the data and when ADCPro was trying to retrieve data, I got the following error message:
An error occured with error code 5055 ads1259evm.lvlib:ADS1259EVM.lvclass/ADS1259EVMPanel.vi:2<ERR> Not Enough data points in file
Could someone let me know what the problem is?
Tao
