Other Parts Discussed in Thread: ADS1251
Using an ADS1251 A-D Converter in the application that measures pressure. I use an analog filter amplifier to buffer and amplifier the sensor voltages but I am losing the four or five least significant bits in the converter output. I studied the data sheet several times and cannot figure this out. The input to converter is correct and the Vref level is correct. I need a better explanation of the input configuration on the chip as well as a better detailed description of the effects that the Vref voltage has on these inputs. This is very confusing to me and ANY help would be appreciated since we are redisgning this portion of our application. Thank you for all your help.
