Other Parts Discussed in Thread: DAC5687
Hello all,
I'm using a DAC5687 chip in a signal processing comunication system. I have two independent systems which outputs a 16 bit real signal each one, in different frequencies. What I want to know is if is it possible to connect one system's output to the DACA and the other one to the DACB, and use the internal adder to combine both signals in one. I want to use de DAC5687 in full bypass mode, without using interpolators, filters,...
I'm also thinking about combine the outputs of the DAC just the way is explained in the figure 62 of the datasheet.
Does anyone have done this successfully before?
Thanks in advance
