Other Parts Discussed in Thread: TLC7524, OPA2237
Dear sir,
I am using TLC7524, SMD IC as DAC. VDD = 5V,Vref = 5V. The output of DAC i have given to OPA2237 ic,which is having +/- 15V supply.
I am able to see my data correctly on data lines, chip select and write signals are also clearly visible. But the output i.e OUT1 shows 15V in any case. Wanted to know what must be the issue? I tried by replacing the IC, but still problem is not getting resolved.
I also tried to take the connections to a different board which has AD7524 DIP package.Its output is given to OP-07.In that case things work properly.
