hello everyone.
i have some problems to retrieve data from ADS1291.
i am using CLK=2.048 MHZ for ADS1291.
can i use SPI CLK =4MHZ?
thanks for your help.
hello everyone.
Hi Wang,
Running your SPI CLK (SCLK) at 4MHz is perfectly acceptable for FCLK = 2.048MHz. During Read/Write commands, SCLK would be limited to 4.096MHz; otherwise, it could run up to 20MHz.
Pages 27-28 of the datasheet further explain the requirements of the clock and SPI interface:
http://www.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=ads1291&fileType=pdf
Hope this helps!
hi Ryan. I still have some problems about ADS1291.
Now i can write/read ADS1291 registers successfully with 2.048MHZ ADS1291 CLK and 4MHZ SPI CLOCK
but it seems that i can't read the converted data correctly.
can i possibly sent you my source code?
hope you can check it out for me.
thanks a lot
Hi wang
Are still struggling with your problem ??I will try my best to help you.
Murthy
