Other Parts Discussed in Thread: ADS1258, TLV2711
Hello.
We're experiencing some inaccuracies in signal data conversion in ADS1258.
We have investigated the phenomenon in our several product boards. By applying different values of a stable DC voltage directly to the analog signals input and reading the converted data, we have created a conversion chart in several boards.
It seems to be a gain deviation factor between different boards. (Deviation range of -7% ... +7% from the expected value)
In each board, all the 15 input signals behave the same, so the deviation is general per each ADS1258 unit.
We have tried removing and installing new ADS1258 units in each board, but the gain factor remained the same in each board, which means that cause is in our peripheral hardware supplying the ADS1258 unit.
The 5v Vref. in all our boards is pretty stable, and the difference between the boards is less than 0.2%.
In general we could calibrate the deviation per each board in the software, but it would help a lot if we could find the factor causing it.
Attached below are some relevant schematics:
The ADS1258 unit:
CLKSEL is drivven Low.
CLKIO is left floating
The Vreff circuit:
Appreciate your help,
Alon Gutman
