Other Parts Discussed in Thread: CDCE949, AFE5808, AFE5808A
Dear Chandu,
the AFE5808 can accept both differential and single ended clocks both in CW and TGC mode and as per datasheet it doesn't seem to make any difference in terms of performances. With that being said, assuming you do want to use the CDCE949 chip and hence a single ended LVCMOS clock, you need to ground the pins CLKM_1x, CLKM_16x, CLKM_ADC. The other option might be to use a differential clock and the best way to do that is to use a single-ended input to differential output transformer like the ADT4-1WT.
The reason why you have a CLKP_ and a CLKM_ pin is just because the chip can be driven by a differential clock as well. So like in every differential signal you need a positive, CLKP_ , and negative, CLKM_, input whose difference is the differential signal you actually apply to the chip.
With regards to the clock frequency required for each input clock, keeping in mind that the CW clock and the ADC one are not correlated and assuming that you want to use the CDCE949 and that it does the job, a possible set of frequencies might be:
