Other Parts Discussed in Thread: ADC08060
I use the ADC08060 for my data switch, use the typical circle, even I force the input to VDD or GND ,There is no output datas,not so much changes from the output.
I would like to know more clearly about your application. If I understand correctly, you are using the ADC08060 in your own custom hardware. You have setup the circuit like the diagram in your post. And you try to input a stimulus signal to the ADC but you do not see the output data change in response. Is this correct?
What is "the typical circle"?
Do you have a separate schematic (in PCB software) that you can provide?
Thanks, Josh
