Hello everyone,
I am a chinese engineer, Recently, I want ADS830E to design a High speed Data acquire card.Now, I encountered a lot of problems about ADS830E. The output data of ADS830E board are all random datas. In fact, I acquired a lot of noise signals when i input a analog signal that was from a output pin of a MCU.I really don't know How to solve them. Who can help me?
Now,I, firstly, introduce my boards to you.
One is MCU board which may read I/O data of ADS830E output pins. The other is ADS830E data card.There is a only A/D IC on this board. The schematic of ADS830E data card is from ADS830E-EVK. However, There is a big difference between my ADS830E board and ADS830E-EVK. The difference is that my board has not AMP OPA681U for Input pin of ADS830E. My board work in single-ended mode.
I directly want to input an analog signals that is a Output signal from a pin of MCU to input pin of ADS830E board that is my board. In here, The Output signal voltage from a pin of MCU is range from 0.0V to 3.3V. Accroding to the datasheet of ADS830E, the signals inputed range from 1.5V to 3.5V in single-ended mode, But my signals provided for input pins of my ADS830E board work range from 0.0V to 3.3V. Does i need a AMP OPA681U for my ADS830E board? I must install a AMP OPA681U on it??
Who can help me? Thank you for your any help.
Sincerely,Yours
Bear19
