Other Parts Discussed in Thread: TS3A44159
Am I correct in assuming that the exposed pad on the TS3A44159 should be connected to ground? I can't for the life of me find it in the data sheet.
Thanks.
Thanks.
Yes the data sheet is a bit rubbish isn't it? I suspect, since the (smaller) UQFN does not have a thermal pad, that it is not internally connected to GND and is for thermal and/or mechanical stability only, so can be connected to GND or not, depending on what is simpler for your application (since the application is not a power one I can't see there is likely to be significant power dissipation anyhow)
