Other Parts Discussed in Thread: DDC114
Does this IC require special PCB material, layout or standoffs?
The DDC114 does not require the use of special PCB material or things like teflon standoffs. Layout is important, however, to assure precision. Suggest you look at the board used in the DDC11xEVM-PDK to see how we approached the layout. The layout is shown in the user guide for this EVM, which you can download from the linked page.
I have never worked at femtoamp level before.
Does TI offer any app notes on this tpic?
Recommended cleaning methods; known issues to watch; best practices; etc.?
There's not an app note that I'm aware of - there are some guidelines discussed in the OPA128 datasheet. Yes, flux can be a big problem, so clean boards are essential to eliminate leakage paths, as is good layout. Again, I'd suggest you look at the EVM and duplicate the layout as closely as possible.
