ICS touchscreen tsc2004 not working in android
Other Parts Discussed in Thread: TSC2004, TCA6424
Hi all,
Porting ics on ti8168. Using tsc2004 touchscreen interface.
Check cat /proc/interrupts when touch on screen  GPIO tsc2004
incremented & getevent utility  for testing all devices events are generated.
root@android:/ #  cat /proc/interrupts
123:          0        INTC  omap-iommu.0
179:          0        GPIO  1-0022
183:          2        GPIO  tsc2004
184:          0     tca6424  Power Button
193:          0     tca6424  LEFT button
194:          0     tca6424  UP button
195:          0     tca6424  RIGHT button
196:          0     tca6424  DOWN button
root@android:/ # getevent
add device 1: /dev/input/event1
  name:     "TSC2004 Touchscreen"
could not get driver version for /dev/input/mouse0, Not a typewriter
could not get driver version for /dev/input/mice, Not a typewriter
add device 2: /dev/input/event2
add device 3: /dev/input/event0
/dev/input/event1: 0001 014a 00000001
/dev/input/event1: 0003 0000 000002d5
/dev/input/event1: 0003 0001 00000090
/dev/input/event1: 0003 0018 00000017
/dev/input/event1: 0000 0000 00000000
/dev/input/event1: 0001 014a 00000000
/dev/input/event1: 0003 0018 00000000
/dev/input/event1: 0003 0018 00000015
/dev/input/event1: 0003 0018 00000023
/dev/input/event1: 0003 0000 000002d1
/dev/input/event1: 0003 0001 00000093
/dev/input/event1: 0003 0018 0000004e
/dev/input/event0: 0001 006c 00000001
/dev/input/event0: 0000 0000 00000000
/dev/input/event0: 0001 006c 00000000
/dev/input/event2: 0001 001c 00000001
/dev/input/event2: 0000 0000 00000000
/dev/input/event2: 0001 001c 00000000
But, Touchscreen not working in android .
Error comes in logcat ANR application is not responding (ANR).
logcat :-
V/EventHub(  134): /dev/input/event1 got: t0=1785654176, t1=963600, type=0, code=0, value=0
V/EventHub(  134): event time 1785654176963600000, now 143303514073
I/InputDispatcher(  134): Dropped event because the current application is not responding and the user has started interacting with a different applion.
logcat when EventHub added devices :-
W/InputManagerService(  131): Couldn't create dir.: /data/system/inputmethod
I/EventHub(  131): New device: id=2, fd=91, path='/dev/input/event2', name='power-button', classes=0x1, configuration='', keyLayout='/system/usr/keylayout/power-button.kl', keyCharacterMap='/system/usr/keychars/power-button.kcm', builtinKeyboard=false
V/EventHub(  131): Opening device: /dev/input/event0
D/EventHub(  131): No input device configuration file found for device 'gpio-keys'.
W/ResourceType(  131): Failure getting entry for 0x7f060000 (t=5 e=0) in package 0 (error -75)
I/EventHub(  131): New device: id=3, fd=101, path='/dev/input/event0', name='gpio-keys', classes=0x1, configuration='', keyLayout='/system/usr/keylayout/gpio-keys.kl', keyCharacterMap='/system/usr/keychars/gpio-keys.kcm', builtinKeyboard=false
V/EventHub(  131): Reporting device opened: id=3, name=/dev/input/event0
V/EventHub(  131): Reporting device opened: id=2, name=/dev/input/event2
V/EventHub(  131): Reporting device opened: id=1, name=/dev/input/event1
I/InputReader(  131): Device added: id=3, name='gpio-keys', sources=0x00000101
I/InputReader(  131): Device added: id=2, name='power-button', sources=0x00000101
I/InputReader(  131):   Touch device 'TSC2004 Touchscreen' could not query the properties of its associated display 0.  The device will be inoperable until the display size becomes available.
I/InputReader(  131): Device added: id=1, name='TSC2004 Touchscreen', sources=0x00001002
V/EventHub(  131): wake() called
V/EventHub(  131): awoken after wake()
I/InputReader(  131): Reconfiguring input devices.  changes=0x00000004
I/InputReader(  131): Device reconfigured: id=1, name='TSC2004 Touchscreen', surface size is now 800x480, mode is 1
idc file for tsc2004 is :
root@android:/ # cat system/usr/idc/tsc2004.idc
touch.deviceType = touchScreen
touch.orientationAware = 1
touch.size.calibration = none
touch.orientation.calibration = none
 But Android application InputDispatcher gives error..Any one help me what happen ??
Thx,
Tejas .
