Other Parts Discussed in Thread: ADS1243, MSP430F449
I have a project where I have interfaced an ADS1243 to an MSP430F449. The ADC has a clean 3.3V supply and Vref is given a clean 1.22V reference.
I have had problems with incorrect readings so I tied input channel 3 to the voltage reference. Most of the time the conversions are exactly half what I’m expecting i.e. 8388607 ADC bits instead of 16777215 ADC bits. Occasionally I have the correct reading. I have checked the timing of my digital communications and I’m confident that they are ok. I have pasted my code for selecting the ADC input channel and taking a reading below. Could you please give me some pointers as to what could be going wrong?
Kind regards
Andrew
unsigned long read_ADC24_1()
unsigned long int value = 0;
char dummy_char = 0;
U0TCTL_bit.CKPL = 1;
adc_CS = 1;
read_try=0;
adc_CS = 0;
// Issue a read command to the 24bit DAC
if ((U0TCTL & TXEPT) == 1) {
TXBUF0 = 0x01;
//adc_time = 0;
while((U0TCTL & TXEPT) == 0);
read_try=0;
tosc=0;
while(!(IFG1 & URXIFG0)) {
if (tosc>50) {
TXBUF0 = 0x01;
//adc_time = 0;
while((U0TCTL & TXEPT) == 0) {
//if (adc_time>=1) {
if (read_try==15) return(0);
if (read_try==5) {
TXBUF0 = 0xFE; // Reset the ADC
tosc=0;
while(tosc<1);
TXBUF0 = 0xF0; // Do self cal
while(adc24_drdy==0);
while(adc24_drdy==1);
read_try++;
TXBUF0 = 0x01;
// adc_time=0;
IFG1 &= ~URXIFG0;
dummy_char = U0RXBUF;
read_try=0;
// Wait for 50 clk cycles
tosc=0;
while(tosc<50);
//adc_time=0;
while(adc24_drdy==1) {
// if (adc_time>=10) return (0);
// Read the most significant byte from the ADC
// We need to send a "dummy" bytes to the ADC to generate a clock pulse
// to clock out the data
TXBUF0 = 0x02;
//adc_time=0;
while (adc24_drdy == 1);// return (0);
IFG1 &= ~URXIFG0;
value = U0RXBUF;
value <<= 8;
//adc_time=0;
//if (adc_time>=10) return (0);
// adc_time = 0;
// Read the middle byte
TXBUF0 = 0x03;
// adc_time = 0;
IFG1 &= ~URXIFG0;
value |= U0RXBUF;
value <<= 8;
//adc_time = 0;
// Read the least significant byte
//adc_time = 0;
TXBUF0 = 0x04;
//adc_time = 0;
// if (adc24_drdy == 1) return (0);
IFG1 &= ~URXIFG0;
value |= U0RXBUF;
adc_CS = 1;
return value;
unsigned long read_ADC24_2()
adc_2_CS = 1;
read_try=0;
adc_2_CS = 0;
tosc=0;
//while(tosc<500);
TXBUF0 = 0x50; // Write to reg 00h (setup reg)
TXBUF0 = 0x00; // reg is 1 byte
TXBUF0 = 0x00; // Set disable burnout and set gain to 1
//adc_time = 0;
while(adc24_2_drdy==1) {
TXBUF0 = 0x01;
read_try=0;
tosc=0;
if (tosc>50) {
TXBUF0 = 0x01;
//adc_time = 0;
if (read_try==5) {
tosc=0;
while(tosc<1);
read_try++;
TXBUF0 = 0x01;
// adc_time=0;
IFG1 &= ~URXIFG0;
read_try=0;
tosc=0;
while(tosc<50);
//adc_time=0;
TXBUF0 = 0x02;
//adc_time=0;
while (adc24_2_drdy == 1);// return (0);
IFG1 &= ~URXIFG0;
value = U0RXBUF;
value <<= 8;
//adc_time=0;
// adc_time = 0;
TXBUF0 = 0x03;
// adc_time = 0;
IFG1 &= ~URXIFG0;
value |= U0RXBUF;
value <<= 8;
//adc_time = 0;
//adc_time = 0;
TXBUF0 = 0x04;
//adc_time = 0;
IFG1 &= ~URXIFG0;
value |= U0RXBUF;
tosc=0;
// while(tosc<50);
adc_2_CS = 1;
tosc=0;
// while(tosc<50);
return value;
void set_channel_1(short channel)
adc_CS = 0;
TXBUF0 = 0x51; // Write to reg 10h (MUX)
tosc=0;
while(tosc<50);
while((U0TCTL & TXEPT) == 0);////////////////////////////////////////
tosc=0;
while(tosc<50);
TXBUF0 = 0x08 | (channel << 4); // Set negative channel to A In common and select AIN channel as positive channel
tosc=0;
while(tosc<50);
//adc_time = 0;
while(adc24_drdy==0) {
adc_CS = 1;
