Other Parts Discussed in Thread: DAC8563, ADS1282
In a voltammetry circuit of a sensor system I am trying to using both ADS1282 along with DAC8563 . But the difficulty is I have one SPI port and I have to use the chip select. What I understood is that I could use the SYNC pin of DAC8563 as a chip select.
My question is that can I use the SYNC pin or RESET pin or PWDN pin as a chip select for ADS1282 ?
What will happen if I will put the SYNC pin of ADS1282 at active low while communicating with another SPI device i.e. DAC8563?
Can any body suggest?
Thank You....
