Is there any improvement in the SNR at lower clock speeds? We plan to use hi-res mode at 15kSPS
Are you referring to input clock speeds or data rate?
By changing the clock speed, you will change BOTH the modulator frequency
Data rate = yes, see front page of datasheet
For the input clock frequency, Figure 46 is the d/s shows the noise vs clock speed, which is pretty flat. So it would make sense the SNR follows similarly.
