I am working on data acquisition of EEG Signal, Prior to data acquisition I need to check the impedance of the Electrodes which are put on the body , so please suggest IC for measuring impedance across the electrodes
Thejesh
Thejesh
Thejesh,
I am still unclear what you want to measure: the electrode impedance or the body impedance?
If you want to measure the body impedance then you can check out the body composition Analog front end device AFE4300 for your application.
http://www.ti.com/product/afe4300
Thanks Praveen
Sorry for the late reply,
I need to measure the body impedance through electrodes,
In my application I have 3 electrodes i.e 1. signal 2. signal reference 3. Ground.
In order to get low noise data while acquiring, the impedance between 1 and 2, 2 and 3, 3 and 1 should be maintained equal so that I can reject common mode noise better. For this I need IC to show me the impedance b/w two electrodes prior to acquiring data..
please help me in this ...
Thejesh,
What device are you using to measure the EEG signal? Is there a way to isolate that device while measuring the body impedance?
Hello Amy Ball,
Thanks for replying
I have separate circuit for EEG and using Analog MUX I can provide isolation for the EEG circuit.
Do you isolate the EEG circuit while measuring the body impedance? If not, try measuring it that way.
