Other Parts Discussed in Thread: ADS4129
I'm using the ADS4129 since a while and recently look to use the internal offset correction algorithm. It seems that when the signal is out-of-range positive with offset correction enabled sample value overflowed if the actual offset correction to apply is positive.
Ex.: In the case of a 2's complement 12bits sample at 2047LSB with a known offset of -5LSB without offset correction enabled. At this point if we enable offset correction this same sample becomes -2044LSB.
Anyone else is aware of that issue ?
