Other Parts Discussed in Thread: DAC8560EVM, DAC8560, DXP
I finally got my DAC8560EVM board working on a MMB0 motherboard using the DXP program. Everything seems to be working OK but I cannot figure out how to disable the internal voltage reference so that I can apply an external reference. I try to send the x480401 command but only 24 clock pulses are generated before the /FSX line goes high. The DAC8560 requires at least 26 clock pulses with /FSX held low in order to execute the command. I tried sending x4804010 but only 24 pulses are sent. I even tried to change the W6 jumper on the DAC8560EVM board to pins 1-2 to hold the /CS line low while sending 2 frames (x480401 and x000000) and this did not work. I do not know what else to try.
