Other Parts Discussed in Thread: TVP5151
需要TVP5151并口yuv输出,需要怎么初始化?
All you need to do to initialize the part is enable the clock and data outputs. Everything else should be OK as the defaults.
BR,
Steve
This does not need to go through the code to initialize? Only need power, use the default settings?
Correct. The defaults are good for 99.9% of use cases.
You only need to enable the outputs.
BR,
Steve
