TY-500 MRI Preamp
Other Parts Discussed in Thread: TL5500
I'm considering standardizing our MRI coil preamps to the TL-5500 part, and am looking  for more information on this part.  It's supposed to be a low noise-figure preamp for use in MRI coils.  Specifically, I'm looking for:
1.  A current data sheet (which is not available on the standard TI website),
2.  The Gerber files (for the board associated with this device) that are referenced in the pdf obtained from the following website (www.mouser.com/catalog/specsheets/TL5500_slas093c.pdf),
3.  Applications engineering support to calculate the appropriate component values for use of this device at other MRI frequencies (200MHz, 53MHz, ...),
4.  Availability of this device (min quantities, cost, supplier, quotes, ...).  I'm told it's a custom device, and am not sure if it can be made available to us.
5.  If the TY-5500 is unavailable, then is there an alternative that is available?
I'd appreciate if any TI Engineer could respond to the above info request and question.  Thanks in advance.
Karim
