I am currently working on TI 8760 but I didn't get output.Here I write the source code.
//#include<pic.h>
#include<p30fxxxx.h>
_FOSC(HS & CSW_FSCM_OFF); /* external clock source , clock switching and fail safe monitoring disable */
_FWDT(WDT_OFF); /* watchdog timer off */
_FBORPOR(PBOR_ON & BORV_27 & PWRT_64 & MCLR_EN); /* enable the Brown-out Reset circuit */
#define FOSC 16000000L // crystal frequency - 16MHz
#define FCY (FOSC/4) //instruction cycle clock freq.
#define WAIT_1uSEC() asm("nop");asm("nop");asm("nop");asm("nop");
#define SD_SDI LATBbits.LATB0//LATBbits.LATB4//
#define SD_SCK LATBbits.LATB1//LATBbits.LATB2//
#define LATCH LATBbits.LATB2//LATBbits.LATB5//
#define SET 1
#define CLEAR 0
//for ti8760
#define TI8760_CONTROLBITS 0x00553005
#define TI8760_ADDRESSBITS 0x00010000
#define LONG unsigned long int
#define INT8 unsigned char
void delay()
unsigned int i;
for(i=0;i<65534;i++)
void write_8760(unsigned long int data)
unsigned char i;
LATCH=CLEAR;
SD_SCK=CLEAR;
for(i=0;i<24;i++)
SD_SCK=CLEAR;
if((data&0x800000)==1)
SD_SDI=SET;
else
SD_SDI=CLEAR;
asm("nop"); asm("nop"); asm("nop"); asm("nop");
SD_SCK=SET;
data<<=1;
SD_SCK=CLEAR;
LATCH = 1;
//LATCH = 0;
SD_SDI = 0;
SD_SCK = 0;
void write_8760_data( unsigned long int data)
unsigned long int dd;
dd = (data | TI8760_ADDRESSBITS);
write_8760(dd);
void init_8760()
LONG temp;
temp = TI8760_CONTROLBITS;
write_8760( temp) ;
void uc_init()
ADPCFG=0xFFFF;
TRISB = 0x0000;
TRISD=0x00;
TRISF = 0x0000;
int main()
unsigned int data_ad=0,i;
unsigned long int data_t=0xffff;
uc_init();
delay();delay();
init_8760();
delay();delay();
while(1)
i=1;
write_8760_data(data_t);
delay();delay();delay();
i=4;
return 0;
