LMP92001 Programming and Reading
Hello TI,
1.  Can you program the 12 Programmable Analog Voltage Outputs on a single I2C write or do you have to perform 12 seperate writes? Note each channel would have a seperate voltage value.
2.  Can you set the device to continuously read each ADC input (which are mux'd), then read the contents for each with a single I2C read command?
