Hi Team,
I found the following note in datasheet page.28.
NOTE
The Serial Interface should not be used when calibrating the ADC. Doing so will impair the
performance of the device until it is re-calibrated correctly. Programming the serial
registers will also reduce dynamic performance of the ADC for the duration of the register
access time.
Does the yellow part mean that the write data of Serial Interface is invalid?
I believe the write data is valid, however would like to confirm just in case.
Yaita
