Hello everybody,
I was following the steps in DAC348x EVM manual:
http://www.ti.com/lit/ug/slau432/slau432.pdf
testing with TSM1400.
The DAC I am using is DAC34SH84 EVM and at 3.4 DAC348x Example Setup Procedure, I provided clock input of 1474.56MHz with output power of 10 dBm and on DAC348x_GUI_v3p8.vi, I set EVM platform on the software menu to DAC34H84/SH84 and pressed SW1 DAC RESET button and pressed RESET USB PORT on GUI. When I pressed LOAD REGS and opened 'DAC34SH84_FDAC_1474p56MHz_4xint_NCO_30MHz_QMCon' file I am keep getting the error below.
There was an error loading the CDCM7005 configuration registers. Please check the file format.
When I opened the file, the context of the file was:
x00 xF29C
x01 x000E
x02 x0052
x03 xA001
x04 xFFFF
x05 x0000
x06 x2D00
x07 xFFFF
x08 x0000
x09 x8000
x0A x0000
x0B x0000
x0C x05A6
x0D x05A6
x0E x05A6
x0F x05A6
x10 x0000
x11 x0000
x12 x0000
x13 x0000
x14 x5555
x15 x0535
x16 x5555
x17 x0535
x18 x280F
x19 x0840
x1A x0020
x1B x0800
x1C x0000
x1D x0000
x1E x1111
x1F x8882
x20 x2400
x22 x1B1B
x23 xFFFF
x24 x1400
x25 x7A7A
x26 xB6B6
x27 xEAEA
x28 x4545
x29 x1A1A
x2A x1616
x2B xAAAA
x2C xC6C6
x2D x0004
x2E x0000
x2F x0000
x30 x0000
x7F x0000
CDCE62005 Registers
Freq:0.000000MHz
Address Data
00 00400000
01 81400001
02 810C0002
03 C10C0003
04 C10C0004
05 29F01A55
06 44AF0016
07 165294A7
08 20001808
2. Change EVM platform to DAC34H84/SH84
3. Press SW1 DAC RESET on the PCB
4. Press RESET USB PORT on GUI
5. Press LOAD REGS and open 'DAC34SH84_FDAC_1474p56MHz_4xint_NCO_30MHz_QMCon'
6. Get error saying 'There was an error loading the CDCM7005 configuration registers. Please check the file format.'
