I'm trying to measure CMRR of our application with ADS1299. (from raw data)
Based on the data sheet of ADS1299, page 20, I'm driving input signal of sine-wave amplitude in CM range (500mV) with frequency 50Hz.
Then, my question is where should I put the ground of waveform generator ?
For our application, we use single-ended, P- as reference and N- as channel-input. Firstly, I shorted out the P- and N- drive signal with waveform generator putting ground in BIASIN (same application as Figure 47 of ADS1299 data sheet). Then, I'm getting pretty bad CMRR, as well as power line noise and harmonics.
If I'm not using the bias-drive, then where should I put ground of waveform generator ?
I believe bias drive further improves CMRR by rejecting remaining common-input of Bias Op-Amp (output of PGA)
