How to remove ripples from ECG signal?
Hi TI,
I am designing Analog Front End (AFE) for Lead-I configuration ECG.
My designed system comprises instrumentation amplifier, band pass filter and notch filter.
Recorded ECG signal is further filtered through 19.5 Hz Butter-worth Low-Pass Filter. This filter implementation is through MATLAB.
I am designing hardware Low Pass Filter of having cut-off frequency of 20-30 Hz by using TL082CM IC.
When signal is applied to 19.5 Hz butter-worth low filter, the output signal is having ripple so there is no smooth curve to identify exact wave shape for P-wave and T-wave.
How to remove ripple from ECG signal?
kindly help me.
Analog Front End
AFE output
Output of 19.5Hz Butter-Worth Low-Pass Filter in MATLAB
  • Ankit,
    If you are asking how to remove ECG ripple using a specific TI device, then please let me know which one so I can better direct your question. If not, then you can try posting a question to the Precision Data Converters Forum, since they have the ADS129x devices that do ECG and have experience filtering signals properly.
