ADS1258 INN & INP
Other Parts Discussed in Thread: ADS1258
Can these pins be left floating when using the ADS1258 in single-ended mode?
  • Todd,
    Generally, I don't like to leave any floating inputs on a board. In this case, there are likely going to be small leakage currents that may pull the input one way or another. The device is on a junction isolated process, so even the mux will some leakage like a reverse bias diode.
    It would be better to tie off unused inputs. I'll refer you to this post that I found on the ADS1258:
    e2e.ti.com/.../364536
    Joseph Wu
