Other Parts Discussed in Thread: ADS1262, ADS1255
I found the measurement accrucy is much better after I applied SELFCAL. Could you recommend how often that I should do a calibration?
Thanks.
Hi Di,
Performing calibration will remove the majority of the ADC's initial error. After calibration though, offset and gain errors will return due to offset and gain error drifts.
The frequency of how often you re-calibrate will be very dependent on your application requirements and which environments you expect to operate the system. Sometimes an internal temperature sensor is used to detect a change in temperature which then triggers calibration
Note: System offset and system gain calibration may be useful to help eliminate other system errors. Self-calibration only removes ADC errors.
Chris
