How to set the channels to single-ended or differential mode in the DAC LMP90100?
Other Parts Discussed in Thread: LMP90100
According to the manual, The DAC LMP90100 has four channels that can work in differential mode or seven channels that can work in the single-ended mode.  But was not written how to switch between these modes. How Is it possible?
    It depends on how you set up the channels using registers 0x20 to 0x2C.
    For single ended you can set it up so that CH0: VIN0-VIN7, CH1: VIN1-VIN7, CH2: VIN2-VIN7… using VIN7 as the common channel.  Or you can use any other VIN as the common input.
    For differential you can set up CH1: VIN0-VIN1, CH2: VIN2-VIN3... or any other combinations.
    You can even combine them and make 2 differential channels and 3 single ended channels.
    Mike
