Other Parts Discussed in Thread: ADS5294
Hi Team,
ADS5294 is being used in a project by customer. The project is for a radar system where there are 128 Tx channels. Eight ADCs are used which effectively provides 128 channels. The ADCs are interfaced to FPGA.
I came across the Sync feature where different chips can be synchronized for data rate. But, it is mentioned that this is possible with reduced output data rate in the datasheet. Can you please provide information on what is the limit on the output data rate? Also, it would be helpful if the voltage level to be applied to the SYNC pin can be provided.
Thanks in advance.
-Best Regards,
Suhas R C
