Other Parts Discussed in Thread: ADS1298
The datasheet for the ADS1298 is somewhat unclear regarding the proper layout procedure for the supplies to the chip. While it recommends looking at the EVM as an example for proper star grounding layout, the EVM datasheet lacks images of the top circuit layer, and also is extremely ambiguous regarding the placement capacitors in its schematic.
With regarding to the star connections, is the ADS1298 datasheet suggesting that I connect all of the AVDD pins, for example, together at one node, and then connect the AVDD1 pin to that node as well?
Finally, with the bypass capacitors, should they both be located near the star connection point for AVDD and DVDD, respectively? And how will designing this on a 2-layer board without a discrete ground plane effect my layout decisions?
Thanks in advance.
