ADS1298 stops to generate DRDY signals
Every time I run my code I send RESET command and stroble the CS pin to reset the serial interface. When I put the ADS in RDATAC mode it performs all conversions as expected to be, generates DRDY signals, all fine.
Then, suddenly the DRDY signal stops. While i can't find the problem, I need to reset the ADS config like when I power off and power on, because performing RESET command in initialization is not working.
