electrode compatibility with ADS1298
Other Parts Discussed in Thread: ADS1298
Does anyone have a recommendation for electrodes that are compatible with the ADS1298. I have been told that the ones I was planning on purchasing are not compatible. I have posted the link to those below.
Link: www.aedprofessionals.com/lifepak-12-defibrillator-monitor-fast-patch-connector-edge-system-electrodes-11996-000092.html
Noel Teku
  • Hey Noel,
    We don't recommend electrodes, but I don't see why the ones you linked to wouldn't work as long as you had some way of connecting them to a board. Why didn't whoever told you think they would work?
    Brian Pisani
  • Hi Brian,
    This is what the sales representative told me:
    "It looks like you are trying to connect a microchip to adult electrode pads is that correct? The plug as far as I know wouldn’t work with that."
    Would the best course of action be to solder/design a connector onto a cable that would allow the ADS1298 to interface with these electrodes?
    Noel Teku
  • Hey Noel,
    It seems like the problem is more mechanical than electrical. If you can find a connector for those electrodes which you can solder to a PCB, then those electrodes can work. Otherwise I know on the EVM for this device we have a female DB-15 connector soldered to the board and it seems that a lot of folks can find ECG cables that plug into a DB-15. In any case you're just going to want some connector that you can easily find the corresponding solderable version.
    Brian Pisani
  • Hi Brian,
    Thank you so much for your help. I have some more questions. Since the ADS1298 is very popular in the medical community, is there a way to connect the electrodes directly to the ADS298? Second, I was searching and stumbled upon a video explaining the ADS1298ECGFE-PDK, I will put the link below. Is this what you are referring to when you brought up the term "EVM"? It looks practical (both in price and functionality), but ideally I would like to connect the output of the ADS1298 to a microcontroller, instead of a computer (as it was done in the video). Would this still be possible? Lastly, do you happen to know the name of the waveform simulator used in the video?
    Link to video: https://www.youtube.com/watch?v=_LY4hHeG-Hs
    Thanks again,
    Noel Teku
