Sir
We have tried to acquire ecg using ads1298 have downloaded the ecg pdk software from ti but when we try to acquire ecg using electrodes it shows as dsp failure
Way might be the problem
Kindly reply
Sir we have fallowed the same steps as given in the below link
In the software part the progress is 0% when we given acquire and no test signal also is acquired it shows as dsp failure but firmware is found wat might be the issue
Hey Sowmya,
I have a couple of questions:
1) Have you followed the software and driver installation instructions exactly as they appear in Appendix C in the ADS1298ECG-FE PDK User's Guide?
2) Are you running Windows 7?
Brian Pisani
yes sir this problem is sorted thank you .
we r able to acquire test and input short signal but not able to acquire lead ecg .
we are using stimulator cable connected to the clamp electrodes.(attached to left arm ,right arm ,left leg)
but we r not able to acquire the ecg signals .
can u plz describe the steps or should we use only use stimulator box only and not electrodes to acquire ecg.
