LMH1251, wrong pulse width of V sync.
Other Parts Discussed in Thread: LMH1251
Dear Specialists,
My customer is using DM365 and LMH1251.
Sometimes V Sync pulse width is doubled and LCD.
He can't find what is the reason.
Could you please see attached file and advise?
What point should he confirm?
I appreciate your great help.
Shinichi
Problem of LMH1251.xlsx
  • Hello Shinichi,
    The LMH1251 produces accurate H and V sync leading / rising edge, but the trailing / falling edge is set by RC delay (in certain cases) which may not be accurate enough. This is also discussed briefly in the datasheet section “H SYNC AND V SYNC CHARACTERISTICS” on page 9.
    If your LCD monitor is using the negative edge for syncing, I recommend that you invert the H and V sync pulses before presenting them to the LCD monitor.
    Hooman
  • Dear Hooman
    Thank you for your reply.
    In this case, Vsync pulse is produced by V, sometimes Vsync pulse width became twice.
    Is this an assumable result?
    The customer wants to know why this phenomenon is happened and what is a measure.
    Shinichi
  • Hi Shinichi,
    From talking to the designer, the answer I got was "the trailing edge is not going to occur at an accurate point, but the leading edge will be". Since he is no longer in my group, unfortunately I cannot push him for more detail.
    I hope you understand.
    Hooman
  • Dear Hooman
    Thank you for your quick reply.
    I understand It must use leading edge.
    I'll send your information to the customer.
    Shinichi
