Pseudo Differential Vs Single Ended Input- Connectivity in ADC
Other Parts Discussed in Thread: ADS1220
Hi All,
Whether I can connect the pseudo differential input as a normal single ended input  in ADC. I have seen many of the ADC's are come with pseudo differential in put
with negative input connect to the signal ground ( from the analog source ) and analog input connect to the Positive pin. Will it be a problem, if  I am connecting -ve
input terminal of the ADC with the incoming analog source ground and our ADC ground ( as we have done in the case: differential input ADC to single ended
application by tying -ve input to ADC ground ).
Best Regards
Sharvy
