Other Parts Discussed in Thread: ADS1158, ADCPRO, ADS1258
i recently purchased ADC1158EVM PDK and wanted source-code to communicate with this ADC. Please provide me with codes.
Thank You
hey Joseph,
Thanks for the reply,.
My problem is i am using the same motherboard MMB0 but my own board containing ADS 1158 chip and various component to connect it to sensors and get data from it..i used ADS1158 EVM as you said before and was able to get all the data but i want to do that using my board which was designed in Eagle n implemented.. I tried to connect through SPI interface from my board to the motherboard.. I connected SCLK, DIN, DOUT CS and GND from my board to the motherboard but i got an error saying DSP not ready..an error occured with error code 6070 libmmb0.lvlib:EEPROM . unable to read EEPROM.
Can you tell me where i am going wrong and what is the procedure if i want to connect my own board with ADS1158 to the motherboard.
Thank YOU
Hi Nischal,
You can find a schematic of the ADS1158EVM near the end of the EVM User's Guide, found here:
You may need to check the state of other pins, such as /PWDN and /RST. Likely the MMB0 is having trouble communicating with the ADS1158.
Chris
Hi Chris,
Thank you for the schematics,
As you said we tried to connect PWDN, RST,all SPI and DRDY to the MMB0 but still it shows the same..EVM/HW incompatible
NIschal
Hey Chris,
I did with the EEPROM and changed it to FALSE as suggested by joseph before. I am connecting the ground from board to the J5.5 as i am using digital ground input and i am powering my board with J5.9 as my board is designed for 3.3V. But still i am getting not compatible.
I also tried with ADS1258 PDK plugin in the software but still was the same. I am not understanding this what could possibly be wrong
Kind Regards,
Nischal
Hi Nischal,
Would you be able to send me a schematic of your board, with some indication of how you're connecting it to the MMB0?
Chris
Since it is a Research and Development project from the company i am not supposed to send the schematics in public can i get your E mail ID through which i can explain more about our board.
Thank you
Hi Nischal,
Certainly. You can email me at pa_deltasigma_apps@ti.com.
Chris
